whirlpool dishwasher gdp4801 851150415831
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool dishwasher gdp4801 851150415831
  • #66025
    bigchrisoioi
    hi guys, the machine pmps, starts to fill and fills to a level then i get 6 flashes …..motor does not kick in…it just sits there doing dowt until i reset program and it pumps to empty!
    is it a motor fault ?…its has a heater built into a sycnro pump?
    thanks in advance Chris
    #362773
    A1engineer
    Re: whirlpool dishwasher gdp4801 851150415831
    6 flashes is flow meter fault, reed switch on left side of appliance as you look at it from front.
    might just need plug cleaned and squeezed a little if not new airbreak or if you can find the part number just the reed switch will be required.
    HTH
    Kevin.
    #362774
    QUICK FIX
    had a similar fault check wiring harness in door for broken wires
    #362775
    Not sure what 6 flashes is but flow meter was always 7 in my experience 😕
    Symptoms suggest it’ll be one of them carppy Askoll style circulation motors.
    Mike.
    #362776
    A1engineer
    F6 is no water intake or machine not detecting any water coming in
    F7 is flow meter faulty
    both these faults come back to a faulty flow meter/wiring.
    #362777
    bigchrisoioi
    thanks, i will be going back with flowmeter and motor,,…..rather not get involved but been dumped on me ….thanks again
