Hi, I have a dishwasher Whirlpool ADP 7572 WH and I wonder if someone know what’s the error code F7 means? This code appears in the begining of the pr-rinse cycle, when the dishwasher starts to fill of water.
F7 = Flow meter failure. Inlet valve defect or water inlet hose blocked. v
The other thing to check is the connections to the module and meter on the air brake. If all ok there then the pressure switch is next point to check. (new models apparently have a lens in the bowl?? haven’t come across one yet, and cleaning that sometimes works).
