Hi. Does anyone know how to test the water temperature sensor (NTC) in a whirlpool G2PDWI/1WH? I’ve measured the resistance at about 50 Kohms at 20C. Is this OK?
Should I buy a new NTC probe and try it? It’s cheaper than a new control board. On startup, the machine fills with water normally but then the buzzer sounds and the fault light starts flashing. The drain pump then starts up.
Can you think of anything else I should try?
Thanks – Kevin.
check the pressure switch its a black round thing that is fitted to the sump on rhs it is removed by turning half a turn it has a honeycomb grill which could be gunged up.
plug out please.
the symptoms you’ve got are the same as one i repaired with a new ntc. but the confusing thing was that the resistance on both the faulty one and the replacement one were virtually the same.
when it sprung to life and has worked for months since, i don’t know why.
