Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool dishwasher spray arm question.
- This topic has 7 replies, 3 voices, and was last updated 14 years, 1 month ago by
iadom.
February 20, 2012 at 6:55 pm #68001
ModeratorModel ADG7440
Fitted a new motor to this, the old Askoll pump was goosed.
Generally working fine but noticed that the upper spray arm nozzle does not appear to be sealing that well at the back of the tub. It appears as though a white rubber washer has perished in the lower of the two holes that the spray arm slots into at the back. Looking on SIOS the diagram is not that clear but it looks as though I would need to order part number 481253029118 which is the complete tube coming up from the base. Is this correct or can I just get the seals.?
February 20, 2012 at 7:40 pm #369261johnmac11
ParticipantRe: Whirlpool dishwasher spray arm question.
The seals are part of the tube, that is the correct part number you have.
John
February 20, 2012 at 8:54 pm #369262iadom
ModeratorRe: Whirlpool dishwasher spray arm question.
Typical Whirlpool, £40 + list price when all I need is a couple of small rubber washers. 😥
Thanks John, I think . 😀
February 20, 2012 at 8:57 pm #369263johnmac11
Try CDSL they have it for £30 + VAT
John
February 20, 2012 at 9:07 pm #369264iadom
Its a tiny fraction less at Masterpart. 😉
Still silly when it is only a 50p washer at best that I need. 😈
February 21, 2012 at 12:02 am #369265leavemetogetonwithit
http://www.toolstation.com/shop/p23104
First one I found on Google but there are plenty more about. If it’s a O ring there’s even less problem.
Mike.February 21, 2012 at 9:34 am #369266iadom
They are flat rubber washers, white ones though, made of the same material as used for the rubber, bungs/blanks in the top of the inner tub on these machines.
She is not to bothered as she says it is working OK but there is some water leaking out from the joint.
February 21, 2012 at 9:03 pm #369267leavemetogetonwithit
iadom wrote:
She is not to bothered as she says it is working OKCustomer’s always right 😉 and if it leads to further problems that’s her lookout.
Mike. -
