Whirlpool dishwasher stops and resets after a few minutes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool dishwasher stops and resets after a few minutes
  • #23426
    Jean1
    I just get a new Whirlpool DWH B00W dishwasher installed that doesn’t work properly.
    1) It starts normally with any program and stops approximately after 5 to 10 minutes. The green light above the start button flashes 2, 6 or 8 times and the program is reset to the first one (rinsing only).
    I suspect a problem with water supply (insufficient flow?)
    2) both red lights “Add rinse aid” and “add regeneration salt” stay on though I filled up 2Kg of salt (I would ignore “rinse aid”).
    3) By the way, why the hell no information is readily available on the fault codes in the delivered documentation (only idiot diagonstic diagram for nerds), on the supplier web site or anywhere else?
    Thank you for help
    #198070
    Re: Whirlpool dishwasher stops and resets after a few minute
    All codes mentioned relate to water inlet problems. Do the obvious – the fill hose is not nipped or trapped when the machine is pushed home? The nasty little plastics tag on the water tap haas actually turned the water fully on? They are shockers for cracking.
    If you are certain that the above points are OK, there may be an issue with the machine itself and you should end for Whirlpool.
