ADP4501 switch on any program, drain pump runs as normal then inlet valve and pump pulse on and off continually at the same time.
can anyone shed any light before i try a new pcb.
You have the wrong board, the one you have is a blank and needs to be programmed by a SAM module
It also looks as if this blank board wont work in your machine even if it is programmed, there are 4 different version of this dishwasher, 3 of them take the blank board yours does not. Correct part number for the board is 481221838273
