Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool Dishwasher top spray arm
- This topic has 8 replies, 3 voices, and was last updated 12 years, 9 months ago by
aroffauz.
July 2, 2013 at 10:07 pm #76082
aroffauz
ParticipantI wonder if any one could shed light on this problem
Whirlpool dishwasher – will fill heat wash and empty but the top spray arm is not rotating properly – checked for blockages – all appears Ok – no restriction to the spray arm revolving – the top basket appears to be sealing up to the feed tube on the back wall ok.
I have come across this on a few older whirlpool dishwashers recently –
wondered if it was to do with a loss of pressure due to the seals the top basket spray assembly join into on the feed tube on the rear wall
Many thanks
Declan 🙂July 2, 2013 at 11:27 pm #397160electrofix
ModeratorRe: Whirlpool Dishwasher top spray arm
dishes in or out
top arm may not rotate properly without dishes in
July 3, 2013 at 8:00 am #397161aroffauz
ParticipantRe: Whirlpool Dishwasher top spray arm
Hi Dave
Do the dishes inside help the pressure to the top spray arm or what is happening that this is the case
Thanks for your advice
Declan 🙂July 3, 2013 at 9:12 am #397162electrofix
does not help pressure but it give the water jets something to push on
July 3, 2013 at 9:23 am #397163aroffauz
Thanks – I never thought of it way
I really appreciate your help
DeclanJuly 3, 2013 at 3:51 pm #397164Criscold
Have you got a model or service number for this one
July 3, 2013 at 6:26 pm #397165aroffauz
The Model number is ADP4400WH
ThanksJuly 3, 2013 at 6:48 pm #397166Criscold
Have you checked where the feed pipe enters the cover plate 480140102074 on the sump, the small latches break off and the pipe pops out under pressure.
Also is it the old askol circ motor on this one as they can cause this.Colin
July 3, 2013 at 7:00 pm #397167aroffauz
Hi Colin
I did check the feed pipe was pushed into its socket on the sump ( I had come across that one before on another Whirlpool machine).
It a capacitor start induction motor rather than than the Askol ‘All else appears ok but when tested without dishes – I had expected the top spray arm to turn ( I had never thought of Daves comment re: the dishes having an effect on the rotating of the spray arm
Many thanks Declan -
