Whirlpool dishwasher tripping fuse box
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool dishwasher tripping fuse box
  • #51552
    nikkinoodle
    Our whirlpool g2pdwi tripped the fuse in our main fuse box (RCD) and does so instantly every time I switch it on. It makes quiet clicking noise first.
    I tried the machine in another socket. It worked for a minute, then the same thing happened again.
    Any advice would be hugely appreciated.
    Cheers,
    Nik
    #308501
    Re: Whirlpool dishwasher tripping fuse box
    Could be anything, unforunately. My suspicion would be that the tray under the machine is full of water and various components will be sitting in it. Clicking noises are usually associated with the pcb relays, so possible that there is a corruption issue going on.
    You’ll have to get in there and find out….
    Power off if you intend to tackle this yourself.
    nikkinoodle
    Penguin45 wrote:Could be anything, unforunately. My suspicion would be that the tray under the machine is full of water and various components will be sitting in it. Clicking noises are usually associated with the pcb relays, so possible that there is a corruption issue going on.
    Cheers Penguin45. I’ll take a butcher’s.
    #308503
    kevibo
    hi, did you find out what the problem was?
