On the side of the machine you will have a water chamber with a flow meter
switch off machine first
take lid off then the side not sure if left or right, you may have a water softener adjuster on the side, if so thats the side you need to remove
there will be a large clear plastic chamber , check for black dirty build up or similar, if so take out & clean. refit and it should be ok after
