Sorry about CAPS – I’m not shouting – this is a long tale – fundamentals follow:
BOTTOM (FAN ASSISTED) OVEN: SET TEMPERATURE TO, SAY, 220 TO START BREAD & IT WILL START TO HEAT, THEN CLICK & REVERT TO 160 WITH INTERIOR LIGHT FLASHING. IF COOKING CONTINUES, TEMPERATURE REMAINS UNSTABLE – ALWAYS REVERTING TO 160. THIS HAS GOT WORSE & NOW WHEN TRYING TO SET TEMP, THE DISPLAY CLICKS & SWITCHES BETWEEN CLOCK, TIMER & OVEN TEMP. TOP OVEN NOT AFFECTED BUT SEEMS COOLER THAN IT SHOULD BE.
WHIRLPOOL ENGINEER HAS BEEN TWICE BUT THE OVEN BEHAVED PERFECTLY! HE SAID IT MIGHT EVENTUALLY NEED A ‘CONTROL BOARD’ – I THINK THAT’S THE RIGHT TERM.
I HAVE FOUND PART ON THIS SITE:
481921478693 – Whirlpool, Bauknecht, Ignis Control Switch PCB
DON’T WANT TO PAY HIS CALL OUT CHARGE AGAIN – COULD THIS PART BE FITTED BY AN INTELLIGENT LAY PERSON / GENERAL ELECTRICIAN? OR DOES IT REALLY NEED THE WHIRLPOOL MAN – IT’S JUST SHORT OF £100 CALL OUT CHARGE . . . . OR IS THE ANSWER A NEW OVEN – DON’T WANT TO DO THIS . . . LANDFILL & ALL THAT.
HOPE YOU CAN HELP.
