Re: Whirlpool double oven door hinges
OK, if you remove the door then check the two screws each side that go into the hinge supports, one may be very loose or even missing or one of the hinges could be worn, although as you say it’s not that old and only the smaller door, it’s normally the large door due to the weight.
Here’s the info if you need it:
Door Hinges 4812 417 18864 – £18.46 each
Door hinge support L/H – 4812 417 18863 – £12.83
Door hinge support R/H – 4812 417 18862 – £16.41
Postage £3.95, all inc VAT.
Let me know if you need any of it spares@ukwhitegoods.co.uk 🙂
