Home › Forums › Public Support Forums › Spare Parts Help › Whirlpool double oven element
- This topic has 11 replies, 2 voices, and was last updated 17 years, 2 months ago by
ACLectrics.
February 11, 2009 at 5:54 pm #43398
ACLectrics
ParticipantI require a circular fan oven element for a Whirlpool double oven. Un fortunately there are no markings on the oven to tell me model or serial number. The element has the following markings on: 1284 396 IRCA R 230V1500W RL6
Hope someone can help!8)
February 11, 2009 at 6:49 pm #277132johnmac11
ParticipantRe: Whirlpool double oven element
There are only about 5 or 6 different types fan elements fitted in Whirlpool ovens over the years. To narrow it down how old is the oven?
Is it a built under oven? and have you a picture of the control panel?The model number on these ovens is either on the profile at the r/h side of the main oven door or in older ones it is in the centre of the frame at the bottom of the oven door.
John
February 11, 2009 at 7:01 pm #277133ACLectrics
It is a built under double oven, stainless steel in colour.
Will try and get pictures shortly, however I have looked all over the oven inside and out, and there are no labels for model number or service number.
The element has 3 electrical connections to it.
Did Whirlpool fit a 1500W element?
Many thanks for your help.
ACLectrics
8)February 11, 2009 at 7:12 pm #277134johnmac11
If it is built under it is probably a stoves made oven, the most common element is 4812 259 98465
John
February 11, 2009 at 7:38 pm #277135ACLectrics
Should this be 4812 259 98405 and not 4812 259 98465 ?
ACLectrics
8)February 11, 2009 at 7:54 pm #277136johnmac11
The number I gave is the most common one for the built under range, the number you have is the same as 481225928823 which you can find in the shop and fits into most single and double eye level ovens.
I cant see a picture of the element in the shop but you can see a picture and dimensions HERE
John
February 12, 2009 at 12:59 pm #277137ACLectrics
I have a picture of the oven and control panel, where can I send it?
February 12, 2009 at 1:03 pm #277138johnmac11
email it to me and I will get back to you later.
John
February 12, 2009 at 7:27 pm #277139ACLectrics
Pictures emailed
Many thanks
ACLectrics
8)February 13, 2009 at 9:58 am #277140johnmac11
Hi Alex,
Looks like model AKP951 and if it is this model the fan element is 481225998465
John
February 18, 2009 at 12:59 pm #277141ACLectrics
I have found the model number under a pile of grease.
AKP950 1X
857795015010Can you let me know the element I require for thew lower fan oven?
Thanks for all your help.
RegardsACLectrics
February 18, 2009 at 1:33 pm #277142johnmac11
Fan element for that one is 481242378001
John
