Whirlpool Double Oven Model AKZ161 Lower Oven Failure
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Whirlpool Double Oven Model AKZ161 Lower Oven Failure
  • #78773
    SimonTai
    Both upper and lower ovens were in use when power to the lower fan oven ceased.
    The LED display stopped, the fan stopped, the oven light switched off . Basically the lower oven stopped working.
    The upper oven works absolutely fine.
    This was a little inconvenient as it happened as we were cooking Christmas dinner !.
    Does anyone know what the problem might be?
    I don’t think its the element as thats gone previously but the fan, light and LED still worked.
    Thanks in advance
    #406855
    stevebunyan
    Re: Whirlpool Double Oven Model AKZ161 Lower Oven Failure
    It could be a number of things and with out putting a test meter on it, it would be hard to say but start with the TOC, then selector switch.
    #406856
    Higgster
    Did you manage to fix this fault?
    I am having the same issue!
    Cheers!
