Whirlpool dryer 3RLEQ8000WW0
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Whirlpool dryer 3RLEQ8000WW0
  • #67044
    SWERV
    Hi, would anyone happen to know the part numbers for the overheat stat, and the thermostat that sits on the front of the drum, or maybe have a parts diagram.
    Merv
    #366067
    Re: Whirlpool dryer 3RLEQ8000WW0
    Pretty sure I got all that stuff from Connect a couple of years ago.
    If you still haven’t found it post again and I’ll have a look.
    Mike.
    #366068
    SWERV
    Hi Mike,
    I still haven’t had any joy with this one. I would be grateful if you can help with this.
    Merv
    #366069
    Have you got a Connect account?
    They have it all listed under 3RLEQ8000JQ 853783315000 which I think ought to be the same.
    There’s a thermal fuse 5031683049586 IIRC on front of trunking,
    a cut out kit (Includes t. O. C & hi-limit thermostat thermal limiter) which goes on side of heater 5031683048978,
    and Thermostat with four terminals (IIRC, two of the terminals are for an accelerator resistor inside it) 5031683034896
    Those are Connect p/nos. I might be able to find other numbers with bit more searching.
    Mike.
    #366070
    SWERV
    Thanks Mike. I do have a connect acoount. I will check that out.
    Regards
    Merv
