If it’s the one I think it is then your Whirlpool part number is 481952878089. Most of the distributors like Connect and Qualtex will have it in stock. I found from experience that you need to remove the top and front and then the large drum will lift out once you have taken off the belt from the motor. This gives you access to the rollers. There are two at the back and two at the front. It can take a while to get to them! :rolls:
