Unit not starting at all and making a loud buzzing noise when the start button is pressed. Have little or no experience of these dryers so can anyone help??
Would the motor have to be replaced with this issue or can arepair be carried out? customer bought a new one on this but i have another unit now doing the same.. is it a big job to strip these units down?
thanks
Motor bearing on the belt end tends to wear allowing the armature to tip and bind.Motor runs fine on its own but as soon as belt fitted it just sits and hums.
Unfortunately the motors are fixed together with liquid metal and impossible to repair.
