Whirlpool Dryer AWZ 3303
  • #57656
    conormccleane
    No drum motion when loaded; when empty very slow drum motion observed; fan housing is clear and no signs of rodent damage; any ideas please.
    Thanks,
    Conor!
    #331857
    conormccleane
    Re: Whirlpool Dryer AWZ 3303
    Just to add that the capacitor seems ok and the service number is 8575 330 15033;
    Conor!
    #331858
    conormccleane wrote:Hi,
    Probably something caught in the front drum support? Unhook the belt and see if it rotates freely by hand? (should be easy to turn) If not drag the drum out and check for obstructions. (they come apart pretty darn easy enough anyway.) 🙂
    Worn belt slipping also could be the problem. 😉
    #331859
    you say cap seems ok have you replaced it to try even with a lower value
    also are both motor windings ok check continuity
    conormccleane
    Belt ok; no obstructions on rollers; BTW any guide available on checking motor windings etc.
