Whirlpool Dryer AWZ 8812
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool Dryer AWZ 8812
Viewing 15 posts - 1 through 15 (of 17 total)
  • #6953
    I need a replacment heating element for Whirlpool dryer AWZ 8812
    but can’t find the part number to order. Please help.
    #120579
    Dave_Conway
    Re: Whirlpool Dryer AWZ 8812
    The part number is 481231018585 priced at £85.32 inc VAT :eeek:
    #120580
    Thanks for that Dave.
    Sorry to ask for more info, but, best place to buy on the net, and
    do you know if it’s an easy job to fit it?
    Miles.
    #120581
    Dave_Conway
    I can supply it for you Miles, add on £3.50 to cover postage. As this part will have to come from Whirlpool it will take 5-7 working days to reach you.
    I have never fitted one of these I’m afraid so I can’t advise how easy it is to fit, although if it’s the same as the earlier models you just remove the rear panel and it’s there, just remember to pull the plug from the socket 1st.
    As you asked about fitting, are you sure the element has failed ? If it is just a “no heat” problem it could be a number of things (and possibly cheaper).
    #120582
    Miles,
    Yes it is relatively easy to fit assuming you are a qualified electrician with the appropriate tools. On that assumption, usually the Thermostats fail on these beasts due mainly to user mis-use, therefore I wonder if it’s just them at fault here ❓
    We can supply whatever part you require to fix either way, for us to supply it’s best to ‘pm’ Dave though first 😉
    Thanks for those replies.
    It is a problem of no heat. I looked through a coupe of other posts
    regarding other Whirlpool dryers, and thought it might be a case of
    replacing the heating element.
    It could well be that it’s just the Thermostat that’s gone, but am not an
    engineer. I work in the television industry and have a fair knowledge
    of things electrical.
    Any way to check the Thermostat?
    #120584
    Dave_Conway
    A simple continuity test, if any are o/c they are faulty 😉
    #120585
    Thanks Dave, I’ll test it tonight.
    Miles.
    #120586
    Hi again.
    Tested the Thermostat, there seem to be two of them? Both are closed circuit. I don’t know if this is good or bad.
    What next? Help.
    Miles
    #120587
    johnmac11
    There is another thermostat behind the plastic plinth on the front of the machine. As before it should be closed circuit.
    John
    #120588
    Dave_Conway
    That’s good in some ways as the stats appear to be OK, although this could mean that the element has failed after all.
    Did you not do a continuity test on the element while you were there ?
    #120589
    I didn’t look round the front, not another one!
    The element was closed circuit – so that’s OK?
    Miles
    #120590
    Miles,
    When you checked the stats on the element, did you disconnect at least one of the leads to each BEFORE checking whether they are open/closed circuit?
    Sure I never ment to re post that last one again.
    Martin, to the last question, no. I didn’t disconnect any of the cables.
    Now I feel like a right chump!
    Thanks to all of you for your ongiong help.
    Miles.
    #120592
    Dave_Conway
    Miles@9 wrote:Sure I never ment to re post that last one again
    Deleted for you Miles 😉
