Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool Dryer AWZ 8812
- This topic has 16 replies, 4 voices, and was last updated 21 years, 4 months ago by
admin.
November 29, 2004 at 1:14 pm #6953
KeymasterI need a replacment heating element for Whirlpool dryer AWZ 8812
but can’t find the part number to order. Please help.November 29, 2004 at 1:36 pm #120579Dave_Conway
ParticipantRe: Whirlpool Dryer AWZ 8812
The part number is 481231018585 priced at £85.32 inc VAT :eeek:
November 29, 2004 at 3:10 pm #120580admin
KeymasterRe: Whirlpool Dryer AWZ 8812
Thanks for that Dave.
Sorry to ask for more info, but, best place to buy on the net, and
do you know if it’s an easy job to fit it?Miles.
November 29, 2004 at 4:11 pm #120581Dave_Conway
I can supply it for you Miles, add on £3.50 to cover postage. As this part will have to come from Whirlpool it will take 5-7 working days to reach you.
I have never fitted one of these I’m afraid so I can’t advise how easy it is to fit, although if it’s the same as the earlier models you just remove the rear panel and it’s there, just remember to pull the plug from the socket 1st.
As you asked about fitting, are you sure the element has failed ? If it is just a “no heat” problem it could be a number of things (and possibly cheaper).
November 29, 2004 at 4:19 pm #120582Martin
Miles,
Yes it is relatively easy to fit assuming you are a qualified electrician with the appropriate tools. On that assumption, usually the Thermostats fail on these beasts due mainly to user mis-use, therefore I wonder if it’s just them at fault here ❓
We can supply whatever part you require to fix either way, for us to supply it’s best to ‘pm’ Dave though first 😉
November 29, 2004 at 4:42 pm #120583admin
Thanks for those replies.
It is a problem of no heat. I looked through a coupe of other posts
regarding other Whirlpool dryers, and thought it might be a case of
replacing the heating element.It could well be that it’s just the Thermostat that’s gone, but am not an
engineer. I work in the television industry and have a fair knowledge
of things electrical.Any way to check the Thermostat?
November 29, 2004 at 5:00 pm #120584Dave_Conway
A simple continuity test, if any are o/c they are faulty 😉
November 29, 2004 at 5:18 pm #120585admin
Thanks Dave, I’ll test it tonight.
Miles.
December 1, 2004 at 10:22 am #120586admin
Hi again.
Tested the Thermostat, there seem to be two of them? Both are closed circuit. I don’t know if this is good or bad.
What next? Help.
Miles
December 1, 2004 at 11:10 am #120587johnmac11
There is another thermostat behind the plastic plinth on the front of the machine. As before it should be closed circuit.
John
December 1, 2004 at 11:21 am #120588Dave_Conway
That’s good in some ways as the stats appear to be OK, although this could mean that the element has failed after all.
Did you not do a continuity test on the element while you were there ?
December 1, 2004 at 2:15 pm #120589admin
I didn’t look round the front, not another one!
The element was closed circuit – so that’s OK?
Miles
December 1, 2004 at 2:19 pm #120590Martin
Miles,
When you checked the stats on the element, did you disconnect at least one of the leads to each BEFORE checking whether they are open/closed circuit?
December 2, 2004 at 8:35 am #120591admin
Sure I never ment to re post that last one again.
Martin, to the last question, no. I didn’t disconnect any of the cables.
Now I feel like a right chump!Thanks to all of you for your ongiong help.
Miles.
December 2, 2004 at 8:44 am #120592Dave_Conway
Miles@9 wrote:Sure I never ment to re post that last one again
Deleted for you Miles 😉
