Whirlpool dryer dont heat?
Home Forums Public Support Forums International Forums European Appliance Forum Whirlpool dryer dont heat?
  • #26065
    vito
    It works normally but without heat.
    I removed back cover and i looked heating resistor.
    I see there two white little ovearheating thermostate, i overtaked both heat thermostates, but still that heating resistor dont heat.
    I tested heating resistor, that works normally, when i put electric, my electric test cable to the resistor its heating…
    Is there another thermostate somewhere?
    -Vito-
    #208633
    Re: Whirlpool dryer dont heat?
    vito wrote:Is there another thermostate somewhere?
    There is an ‘Exhaust thermostat’… near or on the air outlet 😉
    #208634
    vito
    Do you think that is the problem? Or is there something else to check it out?
    #208635
    vito wrote:Do you think that is the problem?
    Yes! :tup:
    vito wrote:Or is there something else to check it out?
    No! :tdown:
    #208636
    vito
    Model is Awz 565 how can i get there?
    Do i have detach everything to get there
    Do i have to change that part, or is there somekind of automatic fuse
    #208637
    vito wrote:Do i have detach everything to get there
    Yes of course, I gave you the information you needed and I cannot elaborate further I’m sorry….
    vito wrote:Do i have to change that part, or is there somekind of automatic fuse
    You have to check the Exhaust thermostat and change it if necessary…OK?
    Go for it….
    #208638
    vito
    Thank you very much Martin.It was quick and good information.
    #208639
    vito
    Okay i think i found it what you said martin, it was plugged with 2 screws in exhaust pipe, is this right part?
    http://www.sparesforhome.co.uk/siteimag … 561714.gif
    I overtaked thermostate and plugged cables together and still that dont heat.
    What you say martin 😆
