whirlpool dryer drum not turning
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool dryer drum not turning
  • #48849
    richy
    Hi guys i have got a whirlpool super capacity dryer mod no 3xLER5435HQ0 .The drum will not start turning when start is pressed motor just humms unless you turn the drum by hand .asume it will be a cap start but not done one of these before . Rich
    #297921
    A1engineer
    Re: whirlpool dryer drum not turning
    does it turn itself once you give it a push, then if it has a cap its cap every time.
    #297922
    spanner51
    as these dryers dont have a capacitor, it will be a motor fault. just make sure the drum is free to turn with the belt off
    #297923
    richy
    yes on inspection there is no capacitor so how does motor start without a cap ? rich
    #297924
    chezza
    It has a centrifugal switch , usually visible on the pulley end of the rotor – worth just checking this hasn’t seized or stiffened, something a quick squirt of wd40 might rectify ?
    #297925
    spanner51
    The motor has a start winding and a run winding.
    When it has started the start winding is disconected by a centrifugal switch, and the run winding takes over. If the spring loaded weights in the motor stick, the switch is stuck in the run position and will just hum when you try to start the machine.
    If you get a loud buzz when you try to start it, it usually because of worn motor bearings.
    Either way a new motor is the only cure
    Hope that helps
    Graham
    #297926
    richy
    thanks for the info especially on a friday night 😆
