Whirlpool DW ADG 722
  • #22171
    kevinlewis
    Semi intergrated with a programme selector and a start button with a light above it that flashes. Thats all it does.Nothing has power except this start light.There was water in the tub but the waste pump was not getting any power.
    Checked the door switch and inspected the selector pcb and main pcb and door harness. Everything looks ok. Did not have the time today to remove from its housing.
    Any ideas?
    #193883
    Re: Whirlpool DW ADG 722
    PCB – 99.99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure. Steady flashing light can be NTC sensor, but programme should abort with drain pump running.
    kevinlewis
    I suppose you mean the PCB at the bottom. I could get the part number from ASD. anyone know if there is a refurbished pcb available?
    #193885
    gegsy
    kevinlewis wrote:I could get the part number from ASD
    Part number is 481221478166.
    kevinlewis wrote:is a refurbished pcb available?
    QER.
    clivejameson
    IIRC if the pump is blocked/faulty it will stop with a flashing start light?
    Have you tried resetting (hold down start for 5 seconds)? The drain pump only should run for 1 minute and then stop, after which it can be re-programmed.
    #193888
    kevinlewis
    Is this information available and where from?
    Ref to 11RC—-is this a fauly code? there is no display on this model only one neon light above the start button.
    #193889
    gegsy
    IIRC = If I Remember Correctlty 8)
    kevinlewis
    returned and reset. found pump blocked. Now working ok.
    Thanks for the advice.
