WHIRLPOOL DW ADG7540/1
  • #37075
    Minge
    The diswasher is constantly beeping as soon as you start the cycle it will drain for a few seconds and then the start pause button is flashing please help me – the element tests ok
    #253396
    DentedPorsche
    Re: WHIRLPOOL DW ADG7540/1
    Hiya,
    Count the flashes between pauses and the fault codes are in the “Known Error Codes” sticky.
    Brian
    #253397
    Minge
    Hi!
    There are no pauses between the flasehs. just constant flashing and beeping.
    #253398
    Constant flashing is F1 – NTC failure.
    Minge
    🙂 cheers for the advice, will give it a try.
    #253400
    Minge
    worked! thanx penguin.
