Whirlpool dw – ADG7560 – F7 code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool dw – ADG7560 – F7 code
  • #80519
    twicknix
    This dishwasher flashes 7 times which indicates a f7 fault code.
    I understand it is the flow meter error. I have not taken the dishwasher out to inspect closely as it’s built in and I was pressed for time.
    I decided to take a gamble to order the parts. Which parts do I need to order?
    The reed contact?
    The can measuring jug?
    The water valve?
    From experience, I rarely have to replace the water valve. Am I right I assuming that the reed contact being the culprit? Does the can measuring jug have the reed contact included? Would I be better off to get the can measuring jug instead of the reed?
    Matt
    Sent from my iPad using Tapatalk
    #413179
    A1engineer
    Re: Whirlpool dw – ADG7560 – F7 code
    give plug at reed switch a wee clean and a squeeze, worst case you need a new one, the pressure switch in sump can also give this error if the black grids all choked with grease
    #413180
    twicknix
    A1engineer wrote: the pressure switch in sump can also give this error if the black grids all choked with grease
    If this is the case, do I need to replace the pressure switch or give it a clean?
    #413181
    twicknix
    It is the reed contact switch. When I turned it on, no water came through then an error code of F6 came on.
    I had to check it out and it dawned on me that I forgot to turn the tap on. There’s me worried then!
    Glad it is all working well. Thanks for the help.
