I have a Whirlpool DWF415 and it aint working !!
If I select a programme and press the button machine starts to fill. (I have opened the door to check this).
After about 15 seconds the machine stops filling and I get a flash code = 6.
The machine just stays flash the code but does nothing else.
If I then keep my finger on the start button the machine starts to drain and stops shortly after.
I understand the flash code 6 relates to the water inlet but water is getting in.
Could the problem be further down the chain i.e. the PCB ??
Any help would be fantastic !! 😀
