Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool DWF 416
- This topic has 5 replies, 2 voices, and was last updated 20 years, 11 months ago by
admin.
April 30, 2005 at 9:31 pm #9311
Keymaster🙄
The machine beeps when the door is closed and no pump or incoming water fill is taking place any suggestions before I start looking inside please.April 30, 2005 at 10:40 pm #133449Penguin45
ParticipantRe: Whirlpool DWF 416
Quite a few possibilities, Bernie. If you hold the start button down for about 5 seconds, you will cancel the existing programme. If you then reset the programme and start it and the fault recurs, when the door is opened you should be able to observe the programme LEDs lit. Which ones are lit can help us with a diagnosis. If you imagine them as numbered 1 – 5 from the left, and let us know, we shoulf be ablle to narrow things down for you.
Penguin45.May 1, 2005 at 10:05 am #133450admin
KeymasterRe: Whirlpool DWF 416
Hi Penguin
When I reset the programme led No 1 from the left lit (rinse Light). I reset the machine a couple of times and it has begun to work again. “
Before I got your advice I had undone and looked at the fittings on the inside and underneath a small black rubber flap valve mark no 28 fell out of the interior somwhere, as I did not see where it came from can you tell me where it is supposed to live.May 1, 2005 at 10:57 am #133451Penguin45
Ah, you must have the power Bernie……. The only flap I can think of off the top of my head is part of the top basket spray tube coupling? No doubt others will recall more.
May 1, 2005 at 11:10 am #133452admin
Bernie wrote:😆
Hi Penguin
Before I got your advice I had undone and looked at the fittings on the inside and underneath a small black rubber flap valve mark no 28 fell out of the interior somwhere, as I did not see where it came from can you tell me where it is supposed to live.I found the position for the black rubber flap valve and it all seems to be running at the moment
May 4, 2005 at 7:00 pm #133453admin
Hi Penguin
You were right everything is working fine again now I really am most grateful for the advice and clues you gave me.
Once again many tahnks for you time in respondiing to my problem.
javascript:emoticon(‘:D’) -
