Whirlpool DWF 416
  • #11446
    Muttlington
    I have a beeping noise coming from my machine and have re-set the machine as described in previous forums, but the beeping continues. The LED lights do not change to describe where the fault might be. I have checked most things in the machine, there are no obstructions and no lack of rinse aid, salt etc. After I have re-set the machine seems to run but the beeping sets in again shortly afterwards. I can’t imagine the water supply has become blocked as it is a built in unit. Any ideas on what I can do next please?
    #145378
    Dave_Conway
    Re: Whirlpool DWF 416
    If the light flashes contantly it’s probably one flash which indicates a faulty NTC (temp sensor) which is not an uncommon fault on these.
    A simple enough repair, check Repairs@ for an engineer who can test this for you.
    If you decide to go in yourself, power off please :zap:
    #145379
    Muttlington
    Many thanks Dave – i think I will call in the experts on this one!
    #145380
    Muttlington
    Dave – I have noticed the ‘Start’ LED flashes twice. Is this fixable or would it require an engineer?
    #145381
    Dave_Conway
    2 Flashes indicates a flooded base/internal leak, try leaning the machine and see if any water runs out from underneath. If the problem continues or recurrs then, yes engineer time to be honest.
