Had this machine for a good few years and apart from repairing a leaking outlet join all has been well until today.
So 9 flashes and lots of beeping, I’ve had the left panel off and pulled the connector from the reed switch pcb, closed up the pins a tad and reseated. Machine continues with 9 flashes and can see that it continues to fill albeit slowly so figure the inlet valve is not closing fully.
Looking for some confirmation and part numbers that this is the part to change, wanted to rule out any other board that might be part if this fault.
Any and all advice gratefully appreciated.
