Whirlpool DWF 416 detergent door not opening and not drying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool DWF 416 detergent door not opening and not drying
  • #11461
    My Whirlpool DWF 416 has suddenly stopped drying properly, and the detergent door does not open automatically. It is possible that these faults both started at the same time, but I cannot be sure about this.
    I have read the instructions and checked all the obvious things like cleaning the filters, checking the spray arms are clean and clear, checking the rinse aid is topped up and the setting is correct, checking the salt is topped up. So if it isn’t a regular maintenance item, I guess it must be a fault or faults. Can anyone suggest what further checks to do or other actions to take?
    Thanks, Steve
    #145436
    bobokines
    Re: Whirlpool DWF 416 detergent door not opening and not dry
    The detergent door and the rinse aid are both dispensed using the same solenoid inside the dispenser. So yes your faults are both related.
    Looks like an engineer visit I am afraid
    Bob
    #145437
    Thanks Bob,
    I am quite keen to have a go myself, do you know where I can order spares and get information/instructions on the procedure?
    Steve
    #145438
    bobokines
    Can you find the service code on the side wall of the door. It’s a long number with a bar code and the word “service”.
    It’s not normally a job we would suggest a customer does himself as it requires strip down. Make sure that you pull the plug before investigating further. :plug: :zap:
    I think you’re looking at about £40 to £45 for the dispenser. I will let one of my colleagues take over from here to find you the part number as my listing does not show your model number.
    Bob
    #145439
    Service: 8542 416 15710
    SER: 33 0125 018246
    also other information:
    mod. DWF 416 W
    Typ: NGPM
    Board service 447011
    Data: 447001
    #145440
    Bob,
    the reply above was from me, with the service number and any other information on the side of the door. Hope this helps and I look forward to hearing from you or your colleagues.
    Steve
    #145441
    Dispenser is p/no 4812 416 68155, around £45 – email to spares@ukwhitegoods.co.uk for exact price and to order.
    Power off when fitting and be exceedingly careful of the stainless steel edge of the door – you can shave with it.
