Whirlpool DWF 416 stopped, light flashes in cycles of 9 and
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool DWF 416 stopped, light flashes in cycles of 9 and
  • #41730
    jimwhat1979
    Hi, any clues as to what this might be please? Stopped part way through cycle and won’t re-start. the lights pulse 9 flashes, pause then 9 flashes again etc. etc. alarm beeps when door is closed.
    #271163
    Re: Whirlpool DWF 416 stopped, light flashes in cycles of 9
    The pcb is unable to turn off the water valve. If this were the case you’d be paddling, so it’s almost certainly a PCB fault.
    jimwhat1979
    Thanks, any ideas on where to get new pcb?
    Any special tools or techniques for replacing pcb or should it be a reasonably straightforward like for like swap with a bunch of plug in connectors?
    I guess it is located in the door somewhere? I have taken door panel off before when replacing dispenser unit so I do know to turn it off/unplug and watch out for the nasty sharp edges and what happens to spring loaded doors when you take the weight off.
