Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool DWF 417W type 12140
- This topic has 12 replies, 4 voices, and was last updated 19 years, 10 months ago by
fifedave.
June 19, 2006 at 6:19 pm #18579
fifedave
ParticipantHi
Got one of these its stopped working, comes on as normal, pumps spins to remove water and the error code which is (reading from left to right) lights 4 and 5 blinking continually.
Hope you can help. Its an Ikea purchased slimline.June 19, 2006 at 7:06 pm #179523gegsy
ParticipantRe: Whirlpool DWF 417W type 12140
fifedave wrote:Hi
pumps spins to remove waterNow theres a novelty 😆
Can you please supply the 12 digit NC number below barcode on door, starting with 85……thanks
June 19, 2006 at 9:17 pm #179524Penguin45
It’s a slimline Bosch in no less than 2 skirts, Greg! 5 button module along top edge of door.
June 19, 2006 at 9:19 pm #179525gegsy
Cheers Chris 😆 Can find test prog but no fault code that matches the reported one
June 19, 2006 at 9:22 pm #179526Penguin45
Reset 2+4, see if it’s just had a little “moment” perhaps?
June 20, 2006 at 7:29 am #179527fifedave
How do i do that reset 2+4 thing then? I can post the code tonight when i can check, if its still required?
thanks for this.
FifeDaveJune 20, 2006 at 8:30 am #179528Penguin45
Hold down buttons 2 + 4 (little white dots under them) – drain pump should run for a minute, when it stops, the computer is zeroed and you should be able to start another programme. If it completes, the computer may just have had a little moment, if not, investigations required.
Penguin45.June 20, 2006 at 8:32 am #179529Dave_Conway
fifedave wrote:How do i do that reset 2+4 thing then?
Hold down buttons 2 and 4 (counting from the left) at the same time for a few seconds, that should reset the PCB.
See how that goes 🙂
June 20, 2006 at 8:33 am #179530Dave_Conway
:wave:
June 20, 2006 at 11:12 am #179531Penguin45
😀 :wave:
June 20, 2006 at 2:57 pm #179532fifedave
Thanks for the advice thus far, i think i may have confused you guys, so sorry and here is my control lay out and detailed description of what is going on.
the service bar code on a sticker on the door has 2 numbers these are:
8545 856 15600 and 990239008883on the top of my door at the extreme left i have one on/off button, on the right hand top of the door reading from left to right i have 5 red leds (these are the programmes pre rinse, rapid etc), a black programme selection button and then 2 red leds for salt and rinse aid.
When i start the machine on any programme the pumps spins and water starts to run through the inlet pipe, just as normal, however after 2 mins it stops, beeps and leds 1, 2 and 3 flash and 5 is lit solid, then after a short period this changes to leds 4 and 5 being lit solid.
thanks again for any help forthcoming.
fifedaveJune 20, 2006 at 4:08 pm #179533Dave_Conway
Now I’ve checked it’s actually a Smeg manufactured dishwasher.
Fault code is E7, if you search the forums for “Smeg and reset” (exactly that without the quotes) ignore the above as that was for a Bosch made version.
Try that and see what happens, if it doesn’t work it’s engineer time to be honest, check the repairs@ link below should you need one 🙂
June 20, 2006 at 7:00 pm #179534fifedave
What an industry – its labelled Whirlpool but manufactured by SMEG, I remember the economics lecture on product differentiation being a capitalist ploy to confuse the bewildered consumer even more, however enough of this Marxist theorising. A massive thankyou for the prompt, detailed and accurate help i have received via my posting, thanks Greg, Chris and Dave.
For the benefit of others heres how i reset my machine and got it working (on a short rinse cycle admittedely but if it packs up again i know where to come).
Door closed, power supplying a switched off machine, open door, switch on and press programme button very rapidly 4 times, switch off. Switch on, led 1 and led 5 should flash, press programme button once, only led 5 should flash, switch off, don’t close the door, wait a few seconds, switch on – should function as normal.
best regards Dave -
