WHIRLPOOL DWF B10
  • #28858
    randomrob
    hi
    I HAVE A WHIRLPOOL DWFB10 DISHWASHER THAT HAS STARTED TO LET WATER IN FOR A COUPLEOFSECONDS AND THEN STOPS, THE START BUTTON BEEPS 6 TIMES THEN PAUSES AND BEEPS ANOTHER 6 TIMES, ANY IDEAS ON WHAT THE PROBLEM MAYBE? ANY HELP WILL BE GRATEFULLY RECEIVED.
    S/N 854241615810
    #220403
    DentedPorsche
    Re: WHIRLPOOL DWF B10
    The number you posted is the model number, the serial is the 2nd lot of 12 numbers.
    However, 6 flashes is normally a flow meter problem.
    Unplug the machine from the mains, don’t just switch it off, pull the plug out.
    Left hand panel off, disconnect the plug to the flowmeter, carefully clean the contacts and plug it back on.
    DP
    #220404
    randomrob
    that did the trick, machine works good as new thanks alot.
