f11 indicates a failure to the water level indicator. It is most likeley to be gunged up. To find it remove the filter tray and you will see a round plastic grid type affair this is the wi switch, if it is gunged up use boiling hot water and a toothbrush and carefully clean, dont be to harsh else you will damage it. This should solve the problem in most cases.
