Re: Whirlpool DWF B10 stops mid cycle
The control board in the facia panel is the likely culprit. There are two versions of the machine, so the 12nc code will be needed for correct identification.
However, consider…….
I cannot guarantee the diagnosis.
The part is likely to be expensive.
There is absolutely no guarantee given on electronics to members of the public.
You may like to consider professional help – use the link below for a UKW engineer in your area.
Power off if you do choose to investigate further.
