Whirlpool DWF10 Not Draining led flashing four times
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool DWF10 Not Draining led flashing four times
  • #29631
    majca1
    I have searched and read several posts and i know that this code is likely to be a drainage problem on the machine. I have dismantled filters etc and cleaned them and i have removed diaphragm switch and it is clean.
    (none of the above were particularly dirty) All hoses to and from the pump appear clean and the pump impeller is clean. The machine appears to run fine until it gets to the drainage stage. i.e. it is circulating water etc.
    Has any body any ideas? Is there a way of testing the pump? Is there a way to test the diaphragm switch? Thanks
    #223885
    majca1
    Re: Whirlpool DWF10 Not Draining led flashing four times
    Machine now fixed. I dismantled the machine again and found a piece of white plastic in the outlet side of the drainpump. I had been looking at the circulation pump. (doh!!)
    Access was really easy. I switched the machine off at mains. Removed the four torx head screws from the panel below the door. Two left two right. The outlet pump is just to the left of the centre of the machine at the front. The pump is removed by turning it half a turn to the left once the clip at the back is released. There was no need to remove the grey outlet hose. Inside the pump was a piece of plastic. At this point I could easily have cleaned all the outlet side of the machine or run water through the outlet hose with a hose pipe if it had been blocked. I could also have replaced the pump if it was broken. Access would have been even easier if I had pulled machine out and laid it on its back. The bottom can be removed too by undoing the two screws at the front on the bottom and sliding the base up off the two plastic pins. Do not remove any screws from the inside compartment of the machine. This will not help and may damage the seals etc.
    I hope this helps anybody else with this problem.
