Whirlpool DWF412 (Ikea) dispenser leaking
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool DWF412 (Ikea) dispenser leaking
  • #23031
    andyg2503
    I have the above which works fine, except that I noticed it was using the full container of rinseaid every time it washed. Then I noticed that when I filled the dispenser, closed the lid of the dispenser, and then lifted the door of the dishwasher, the rinseaid was running out and down the door from underneath the dispenser.
    Any ideas? New dispenser? If so, is it a door off job?
    Andy
    #196835
    Re: Whirlpool DWF412 (Ikea) dispenser leaking
    That’s definitely an odd one……… Is there a gasket under the rinse aid cover? It should seal completely. Dispenser is about £45 plus VAT etc if required – some individual components are available.
    Access requires the door outer panel to be removed.
    Stay safe, power off.
    Simon46
    Yes a blue disc has not been found in the diswasher has it? should fit in rinse aid lid.
    Regarrds
    Simon
    #196837
    andyg2503
    No I’ve never seen a blue disc, and we’ve had this machine for 6 years.
    Anyway, I don’t want to have to strip this door twice if I can, and I don’t want to buy a new dispenser if not required. So do you know if on the back of the rinseaid dispenser, there are any pipes or seals that could easily have become detached, and it’s just a case of stripping the door and effecting a repair, or is it something more serious (like the dispenser is split) and it’s a definate new dispenser job.
    Thanks, Andy
    #196838
    The dispenser may be leaking for a number of reasons. We have mentioned that there should be a sealing gasket under the dispenser cover. If the dispenser is not visibly cracked from the front, you have no choice but to inspect it from the inner side of the door. There will be a large streak down the inside of the panel if it has split.
    Can’t tell you much more, really. Mind the edges of the door panel – you can shave with them and make sure the power is off.
