I would appreciate any help with the following problem:-
1) green start LED on.
2) shut door – motor starts, no water coming in, beeping.
3) after 30 secs, motor stops, beeping continues.
4) open door, beeping stops.
Then – press stat for more than 3 secs
5) shut door
6) motor starts, no beeping, no water
7) after 4 mins exactly beeping starts, motor still running.
8) open door, start LED flashing, beeping stops.
I managed to get a copy of a test procedure but can’t seem to get this to work as none of the LEDs light up to give the fault indication.
Many thanks for any suggestions
Tom
