Whirlpool DWFB10 stopping with beeps and 4 x LED flash
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool DWFB10 stopping with beeps and 4 x LED flash
  • #11513
    Hi there,
    I have a Whirlpool DWFB10 dishwasher which was purchased with an Ikea kitchen. It’s worked for a year, but just recently is stopping half way through the 40 degree Rapid cycle. When it stops, it has a beep that goes on and off constantly until you open the door. The door panel control (the diamond shape with a ! in) flashes 4 times. Does anyone have an idea what might be wrong?
    #145617
    ali-p
    Re: Whirlpool DWFB10 stopping with beeps and 4 x LED flash
    that will be an ‘F4’ – draining failure
    does the appliance drain out fully?
    If no – check filters + drain hose (also if conected to sink the spiggot) for blockages & kinks
    If yes, could be the level sensor jammed up with grease (happens ifyou use the cooler washes a lot). Try pouring some hot (70 deg) water into the base – but not too much, only 1 inch over the filter!
    if neither works – call an engineer!
