Re: Whirlpool DWFB10W no power
The fill hose weeping down the back and into the undertray is the obvious one to go for – water and electrics is a good combination………..
Otherwise, it’s a process of elimination. Heater and mains suppressor will cause shorts. Output hose from the circulation pump splitting will soak everything and cause shorts. Possible broken wiring in the door, although that is quite rare these days.
Stay safe, power off if you’re sorting this yourself.
