2 years old and no ID anywhere on it.
Select a programme, door does not lock although light is on then F09,overflow, door lock light flashes. This is on any programme including drain. Customer says the occasional FA also.(aqua stop failure) Is this the pressure switch?
When I arrived the pcb was loose and has been banging on the tub.
have checked pressure pot and switch but no difference. Any advice as to whether it is the pressure switch or door lock appreciated.
Rob
