whirlpool element
Viewing 15 posts - 1 through 15 (of 21 total)
  • #44722
    LJDomestics
    does anyone know were i can get a awo_r4205 element at a sensible price?
    part number :481225928823
    I cannot seem to source this for anything less than £59 from any of my suppliers.
    Or alternatively anyone know if there is a patent variant rather than a genuine as i think 60 pounds is a hell of a price for a w/m element.
    Regards in advance
    Also am i really having to extract the drum to replace this part … upon investigation it appears to me this cabinet is spot welded throughout… seems like a lot of work just to replace a part that can be quite prone to future replacements.
    #282061
    Washman
    Re: whirlpool element
    481225928823 is £34.27 from Electrue/Connections.
    Mike
    #282062
    bazza500
    £34 ish from connect
    #282063
    bazza500
    Damn you Washman!! You type too fast!!
    #282064
    LJDomestics
    thanks for 2 very quick responses..however i have a account with connections and this is were i sourced it from yet im getting a price of £46.49 + VAT and p+p
    qualtex want 36.46 for it + vat and p&p but NIL stock.
    they do seem rather pricey!
    #282065
    looks standard whirlpool fayre to me, front should come off.
    #282066
    LJDomestics
    hey mike.. thx for respose, we are talking the same source? i.e connect distribution? its just i have a different price than what your suggesting from the same source.
    #282067
    cornwell40
    Ah I hear the lid opening on the worm can again 😉
    Put Connect in search. MANY different prices depending on your account and how much you spend 👿
    TC
    #282068
    LJDomestics
    cornwell40 wrote:Ah I hear the lid opening on the worm can again 😉
    TC
    OUCH!! Is that really the case? Seems terrible if thats the case.
    #282069
    cornwell40
    £34.27 to me too. Odd….same prices from Connect 😉 .
    TC
    #282070
    LJDomestics
    £46.49 +vat and p+p to me from connect.
    #282071
    £37.20 to me.
    I’d take a good look at the pic and the details (240mm, 2050watts) and take along whatever you have in stock which might fit, if the job’s not too far away. (Tell customer that correct part is both much more expensive and would take time to get hold of, if they ask). In situations where it is necessary to wait for part, I leave old heater in but disconnected and advise customer to use hot fill only programme to fill machine or use cold wash. Though this is more difficult with modern machines.
    Mike
    #282072
    LJDomestics
    once again thanks for reply…
    Ive sourced what i hope to be a suitlable replacement off europart..
    I put in the original part number and they came up with 34-wp-10 as a suitable replacement only their picture lists it at 247mm and doesnt list the wattage (2050) as the original is, yet the original off connect lists it at 240mm…. im just hoping europart is measuring it end to end and connect from the fixing plate then this would seem correct.
    Anyone ever used 34-wp-10 and is it correct?
    Hopefully it is as its a lot cheaper off europart.
    Im also surprized a failed element didnt trip the customers consumer unit… modern house modern fuse box…. am also wondering if it may of damaged the board / pcb… never checked that but will do before i fit a new element.
    #282073
    LJDomestics wrote:
    Im also surprized a failed element didnt trip the customers consumer unit… modern house modern fuse box.
    Was it showing low insulation on the megger? An element can go o/c without going low insulation. Especially if there’s a pressure switch issue and the element overheats, blowing its internal toc. Best check that if so.
    Mike.
    #282074
    spimps
    Had the same model this week with an O/C element and as soon as the machine locked the door the service light comes on.
    Pricey element though.
