Whirlpool error code question ??
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool error code question ??
  • #76043
    stin74
    Im getting an error code on my machine saying f08 which according to a code thing on here indicates: Heating element open circuit
    Check: Water heating element, relay, wiring
    is it likely that the element needs replacing ?
    The model is Whirlpool AWOD6527
    #397018
    Re: Whirlpool error code question ??
    stin74 wrote:Im getting an error code on my machine saying f08 which according to a code thing on here indicates: Heating element open circuit
    Only if you follow the advice given in your post, CHECK HEATER. 😉
    #397019
    stin74
    So it is likely to be the heater element thats gone then from that error code?
    im not sure how to check the relay etc, but a mulitimeter can be used on the element
    #397020
    stin74 wrote:So it is likely to be the heater element thats gone then from that error code?
    Error codes are for guidance only, they give a strong indication of where the fault could (but not necessarily does) lie.
    stin74 wrote:i’m not sure how to check the relay etc, but a mulitimeter can be used on the element
    The relay forms part of the main PCB so with your multimeter check both the heater AND the wiring to and from the PCB. Inspect the PCB for any burnt tracks while you’re at it!
