Whirlpool F/F test / codes
  • #28497
    a1al
    I am trying to repair a w/pool S20BRSB21-A/G side by side F/F everything looks and sounds like it should, but a relay on the power pcb at rear sounds dodgy does any body know how to run a test mode and what the codes are??
    Many thanks
    a1al
    #218597
    subs
    Re: Whirlpool F/F test / codes
    What do you mean sounds dodgey?
    Subs
    #218598
    a1al
    There is a relay on the PCB making a clicking noise
    Do you know how to run the test on this model
    many thanks for your reponse “subs”
    #218599
    subs
    The relay clicking is quite a common fault on these only cure i know is to replace rear module. Dont know test for this im afraid.
    Subs
