Machine has just been moved to a new house and throws up F23 on first attempt to use.
Apparently F23 can be heater or pressure switch related. Meggered element and it is down to earth. Removed both wires from element and tried again, this time I got F08, is this related to an O/C heater fault?
But if you remove the heater feed the electronics can’t self check but instead through up erroneous codes I’m guessing. Change the heater and all will be tickerty boo (cough) fingers crossed 🙂
