whirlpool fan oven error code F03
Home Forums Public Support Forums Help And Support Cooker And Oven Forum whirlpool fan oven error code F03
  • #8634
    Any help on this would be appreciated.I have been told its board trouble.
    #129755
    DentedPorsche
    Re: whirlpool fan oven error code F03
    Hiya,
    error code normally a faulty capricorn module. (Main pcb board).
    DP
    #129756
    DentedPorsche wrote:Hiya,
    DP
    Thanks a mil D.P. Gives me something to work on.
    Regards D.B.
    #129757
    Hi DP,this is model AKZ451/IX 2.3KW I checked out main board mounted on top of oven casing,could not see any blown components or breaks in circuits.Did the same with the controls board [gemini].Probably needs to be checked on test unit which I dont have.Any chance you could get me part numbers and price on replacements.
    Regards D.B.
    #129758
    Are you quite sure you want to do this?
    4812 310 28197 – power unit – over £90
    4819 214 78693 – control unit – nearly £50
    All plus VAT etc.
    I would seriously suggest getting some pro help – throwing parts at it will get very expensive, very quickly. 🙁
