Whirlpool fan problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Whirlpool fan problem
  • #8702
    I have a Whirlpool AKG 668 double oven in which the fan oven has stopped cooking properly. On looking inside the fan at the back is not turning so I guess that means the fan motor has died. There is still heat being generated and it claims to be getting up to temperature so I have concluded that the elements must be OK?
    How easy is it to change the fan assembly and what is it likely to cost to get the spare?
    Gill
    #130076
    Re: Whirlpool fan problem
    New fan unit (Part No: 481936178208) will set you back around £150 🙁
    Don’t panic at the cost – spares@ukwhitegoods.com will probably be able to source a suitable replacement at a significantly lower price. It may well be after the Bank Holiday however.
    Martin wrote:New fan unit (Part No: 481936178208) will set you back around £150 🙁
    Typical Whirlpool then, three times the price of anyone else for spares! 🙄
    Dave_Conway
    Penguin45 wrote:It may well be after the Bank Holiday however.
    Or sooner 😀
    That’s a Stoves made oven, Gill, please check around the door area for the rating plate and let me know the numbers from it, especially the one beginning 059????.
    I’ll get you the real price then from the manufacturer rather than what Whirlpool decide to charge for the part 😉
    #130080
    Thanks for all your replies.
    The number starting 59… is 059040445
    Gill
    #130081
    Dave_Conway
    Stoves part number 081581800
    Here in the shop for you Gill at a slightly more realistic price 😉
    http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … Motor.html
    #130082
    Thanks Dave,
    a much better price! 😀
    Any top tips on installation?
    Gill
    #130083
    Gill_O wrote:Any top tips on installation?
    Ah! That’s where we cannot help for certain legal liability reasons 😉
    See the link below on that:
    viewtopic.php?f=5&t=4386
    However, DO ENSURE THE MACHINE IS FULLY ISOLATED FROM THE POWER SUPPLY (WHERE NECESSARY – AND IF AT ALL POSSIBLE REMOVE THE FUSE :zap:
    ….one additional tip…..a spray can of WD40 may help in getting the old unit out :tup:
