Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool fault 3 flashes
- This topic has 8 replies, 4 voices, and was last updated 16 years, 6 months ago by
griffo7273.
September 30, 2009 at 8:27 pm #48980
griffo7273
ParticipantCan someone help me before my wife starts to asking me to wash the dishes by hand 🙁 🙁
Whirlpool ADG332SWH
This seems to be an intermitant fault, it seems to stop mid cycle and reverts back to rinse mode with the start button flashing 3 times???
I hold the button in and the pump cuts in and sometimes this clears it and the cycle can be started again other times it just reverts back to rinse again?
Any ideas welcome please
Cheers
October 1, 2009 at 7:22 pm #298387griffo7273
ParticipantRe: Whirlpool fault 3 flashes
Please any ideas ?? quick the Mrs has bought me PINK rubber gloves today 😯
October 2, 2009 at 1:35 pm #298388martinm
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
you need to check the heater first remember to unplug mains first
October 15, 2009 at 3:14 pm #298389griffo7273
how do i go about checking for this fault?
im quite compitent so any advice would be great.
Cheers
October 15, 2009 at 4:28 pm #298390gegsy
Measure the heater with a suitable ohm meter 😉
Unplug appliance first.
Be looking for app 20-30 ohms reading.Greg
October 17, 2009 at 3:40 pm #298391griffo7273
Gegsy
thanks tested that 29 to 30 ohms being resd, what power should be going to it when in run mode ??? with this reading could the heater still be knackered???
have just put back together will run it again but on last run there defo was no heat just cold wash
Cheers
October 17, 2009 at 7:33 pm #298392griffo7273
yep no heat at all everything else seems to be working !!!! help
Is it buy a new heater and try time?????
October 17, 2009 at 8:43 pm #298393Penguin45
The heater is powered directly from the computer board. If the heater is showing resistance and you get a very similar reading from the connector to it at the pcb end, the fault more or less has to be the pcb.
October 17, 2009 at 9:13 pm #298394griffo7273
So is this a replace and see? can i check any further?
there does seem to be a slight bit of burnt carbon on the top of thr relay housing!
Cheers
