Whirlpool Fault code – FP
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool Fault code – FP
  • #52844
    PearlMk1
    Hello, have a Whirpool 1200 AW03571 and couldn’t find anything using the search button
    Basically towards the end of any cycle the machine will stop and flash FP (Clean pump, draining fault)
    I have removed and cleaned the filter (would a new one make a difference?)
    And also removed the black pipe from the bottom of the drum, which there was a plastic ball sat?!? I assume this shouldn’t be here so I removed it?
    Anyway I poured water through the drum which came down and out through where the filter sits….
    Is there anything else to test or ami doing the right things to fix this?
    I rent the property so would rather fix this quickly (Unless it needs a new pump?) than have to get in touch with landlords etc who live over an hour away!
    Many thanks for any help!
    #313341
    spanishwhite
    Re: Whirlpool Fault code – FP
    Put the “plastic ball” back in.It is supposed to be there
    #313342
    PearlMk1
    Ok I have just put the ball back in! Any ideas on what this can be?
    #313343
    spanishwhite
    To be honest you are better off calling your landlord.It could be a failed pump or a blocked pump.Not wishing to be unkind but if the machine is not yours and i personally would not mess with it.
    #313344
    PearlMk1
    Ok thank you
    #313345
    You could always check the coupling to the sink spigot (if appropriate).
