Whirlpool FF Cutting Out!
Viewing 1 post (of 1 total)
  • #61389
    subs
    ARC7479 85017471500
    This FF will come on, run for a while and get down to temp but will cut out and not come back on again. If you play with the “stat” in the fridge it will kick in again only to do the same again later.
    This is electronicaly controlled. The defrost system checks out fine. The “stat” in this is described as a potentiometer. I’m wondering if it’s this at fault. Anyone familliar with this one?
    Subs
