Whirlpool FF problems
Viewing 1 post (of 1 total)
  • #38658
    MG23
    Hi, I have a whirlpool side by side ff S20BRBB20-A/G which is 5 years old. Last year the fridge started to get warm, although the freezer worked fine, the bottom vent in the fridge was ice bound. I tried a 24 hour defrost, but nothing helped. Ended up paying for a new control pcb unit which solved the problem. Alas, I have the same problem again. I have an internal fridge thermometer registering 15 degrees although the led on the door says 5. The vent at the bottom is covered in ice again. Have tried a defrost, but is exactly the same again. No other problems. Is this the control pcb again, or could it be the thermostat? Any advice much appreciated thanks.
    8586 152 15000 and 110247 006077
